@johnsonshiue, That is somewhat unfortunate for an application I was intending to use Model States for. I have been watching this thread because it was already asking something I was intending to get into soon myself. We are late adopters of Model States - we're just now in the process of upgrading from 2021 all the way to 2025.
I understand the current behavior of Model State BOM's. This behavior is what I would want most of the time, when I'm using Model States for creating variations of a design.
However, we also often have to develop drawings showing the process of removing and replacing large equipment in a customer's facility. Normally these drawings have been done by our Project Engineering department using AutoCAD. A few of our Project Engineers dabble in using Inventor for this purpose, but it is a bit cumbersome because it requires using a combination of View and Positional representations.
Model States seem like a perfect solution to showing these operational steps without having to pair up two different types of representations to do so. The BOM is where this idea gets tripped up a bit. In this case, we would NOT want each step to have its own BOM. It is one set of equipment performing the job - it just isn't all visible at the same time, and the Model States represent these operational steps. We would want a single parts list that can be referenced by multiple views using different Model States. I was hoping that there was a setting somewhere that allowed you to pick which BOM method you wanted to use for a particular assembly.
It sounds like that's not the case. I'll have to figure out some solution for getting around this issue if I want to proceed with using Model States for these project drawings.
