BOLTED CONNECTION PROBLEM
hi everybody!!!
I'm doing an assembly in Inventor and I have to place many bolted connection, but when I finish the bolted connection command the bolts are placed in a wrong location.
I attach 3 pictures about this
I don't understand whap happen
Please help!!
Hey Albert,
While selecting the holes, if the part has multiple patterns,try to repeat the process for individual patterns.
Let us know if it works.
Hi!
I tried to put just one bolted connection without follow pattern and the same occurred
In the pictures attached we can see that while executing the command the preview of the bolted connection is right, but when I finish the command the resulting position of the bolt is wrong.
In fact the restrictios of the bolted connection are rigth but the position is wrong.
I think this is an error of the system because I have another similar assemblies and this is OK, Just in this project I have the problem.
Thanks for your atencion.
