Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Bolted connection - New hole definition
fce
fce
Hello there,
I would like to add a new hole type to the menu in the bolted connection. It could be added to the existing ISO family or to a new one.
Basically similar to the "ISO-Hex Head Cap Screw ISO 24017", but instead of a though-going hole, it would have a threaded hole and a counterbore. A short list of different counterbore diameters and depths is needed, but the best would be to use the custom dimensioning type.
Two pictures enclosed with some details.
How can I add a new hole type in bolted connection?
Best regards,
Francisco
Gabriel_Watson
fce
In that topic I could only find how to add new fasteners, but not new hole types.
Franck_DELCUSE
Dear,
With complycity of Brendan GALESNE
You must modify 5 xml files into 3 folders.
See Below:
  • ID Style list
    • C:\_TravailVAULT\Standards\Styles\Design Data\Design Accelerator\Tables\_TablesMap.xml
  • Data style
    • C:\_TravailVAULT\Standards\Styles\Design Data\Design Accelerator\Tables\Holes\DIN.xml
  • Style name
    • C:\_TravailVAULT\Standards\Styles\Design Data\Design Accelerator\Tables\Holes\holes.cfg.xml
  • Standard style list
    • C:\_TravailVAULT\Standards\Styles\Design Data\Design Accelerator\fr-FR\Tables\Holes\DIN.res.xml
  • standard style name list
    • C:\_TravailVAULT\Standards\Styles\Design Data\Design Accelerator\fr-FR\Tables\Holes\holes.cfg.res.xml
Be carful of <Type> into « holes.cfg.xml », all must be the same. If <Type> = 4 dans « holes.cfg.xml » (milled), then « DIN.xml » column « <HeadDepth Description="%6%" Units="mm"/> » must be change to « <HeadAngle Description="%7%" Units="deg"/> » and all column « <HeadDepth>xxxx</HeadDepth> » must be replaced by  « <HeadAngle>yyyy</HeadAngle> »
