Bolt Connections - Cannot Edit
rogieA
rogieA
Hi, I created bolt connection fine, but when I need to edit the bolts and nuts, it seems that the "ok" button is greyed out and not clickable? However, some of the Bolt connection i created from my assy works fine during editing.. Is there something I am missing? Appreciate your help.. tnx
Xun.Zhang
Hi Rogie,
It seems you have to select a plane to place it again from your image, try to pick up a start plane and terminal plane and retry.
Thanks!
Xun
johnsonshiue
Hi! The dialog shows the Start Plane is missing. You need to select a Start Plane.
Many thanks!
Software Test Engineer
rogieA
Great! problem solved.. many thanks!!
@Xun.Zhangwrote:
Hi Rogie,
Thanks!
Great! problem solved!  Many thanks Xun Zhang...
rogieA
Thanks for the solution.. Problem Solved!  Many Thanks Johnson!!
