How to draw a blade as simply as possible? Model as an attachment (Blade_Model.ipt)
The blade is drawn by surface modeling and cut to the correct shape
and given the thickness.
I would like the model to be simple so that it is easy to control, because all dimensions
are changed so the model needs to be good(simple)
The model also needs to get a flat pattern.
Can someone draw / help an example model of how this would be done most easily?
