Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
So I imported a step file from Ashes software with multiple airfoils. When I am trying to loft them, it doesn't connect them as a solid, but when I select surfaces, it works? So do you have any idea how I can make a solid body from these airfoils?
Solved by alina28_. Go to Solution.
Solved by kacper.suchomski. Go to Solution.
Hi
You can create solids from surface segments using the Sculpt or Stitch tools.
Kacper Suchomski
Unfortunately, without input data (cad file) we are unable to guess anything.
Kacper Suchomski
And ipt?
Kacper Suchomski
Where are your surfaces?
Kacper Suchomski
Yes, where are your loft surfaces?
Kacper Suchomski
It works 😏
Kacper Suchomski
