Announcements
Bevel gears not acting properly to keep screw shaft straight
Hi there,
I am trying to use dynamic simulation as part of a project and would like to get the archimedes screw shaft to only rotate around the x axis of the assembly, whereas it is currently rotating around the z axis of assembly. I want it to be aligned with the couplings at the top and bottom of the cube and remain straight so that the power transmitted from the coupling can rotate the screw. I have attached a zip folder containing the files, with the assembly being under 'assembled box - copy(3)'. Any help would greatly be appreciated.
Thank you
maciej.wiankowski
Have you tried constraining it to an axis? If the axis is not ideally XY, etc. you can xreate a point and then create an axis between the bushings and and then constrain that part to that axis?
I cannot open that assembly as I am using inventor 2019.
3D4Play
+1 on Maciej's reply. Try constraining the auger axis to the bushing (bearing, whatever it is?) hole axis and see if that doesn't help
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
Check your geometry, it appears the holes in the box don't align with the Shaft3withGearandScrew when all of the other rotational constraints are set.
As a general practice, I would attach the bearings to the box first, then the rods to the bearing, then the parts to each other. I find using Insert Constraint or Assemble works best for cylindrical faces and edges at once and can turn on lock rotation if needed.
Please select the Accept Solution button if a post solves your issue or answers your question.
Thank You so much! After messing around with it for a day, i was able to achieve the desired results.
Still new to all this... haha
WHolzwarth
Did you really succeed with matching teeth in DS? I've spent some time with finetuning ..
Walter Holzwarth
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
