Hi
My 2 cents worth.
Don't use Windows explorer to copy/rename your files. This used to be the only way to do this a few years back, but there are better tools available now.
Depending on the quantity of files you need to process, will determine what method you use.
(You have already answered your question with the link supplied.)
The easiest it to do the "save as" method. (But can become tedious if you want to do a lot of files at one go)
- Start with the Assembly
- Progressively "Save and Replace" each sub assembly/part
- The from each part, replace any derivatives.
Then Open each drawing/s and do a "Save as" for each one. (If multiples)
- For each new drawing use the "Manage/replace model reference" and select the 'New' Part/assembly.
The next method is to use the Design assistant
This works really well for multiple files and assemblies
I Personally have not used it for the corresponding drawings, so I still do the drawings manually, as above.
The last one is to use the iLogic design copy method.
This one is really cool, and works a treat, but it might not give you exactly what you want, as you still have to quite a bit of leg work to fix, part numbers and drawing names and numbers.
You only have the option to add a Prefix or Suffix to the file names, but all links and part numbers are updated, including 3rd party files.
I use all three methods, but the most common one is the basic "Save As" (Method one)
I got some iLogic code a while back (From the forum) which changes the derived component reference. This will be a requirement, as there is no easy way to do it via the "Save as " method.
Hope this makes sense.
Reg
2026.1
