Best way to connect parts smoothly
msohaibPLAF8
msohaibPLAF8
How can I create a seamless transition between these two parts shown in the image? Any advice on the best approach for achieving this would be greatly appreciated!
Thanks!
Replies (10)
Alexander_Chernikov
Are these two different parts or one part?
It is advisable to attach a part/assembly file and a sketch of what kind of transition you need to obtain.
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
ampster40
with nothing else to go from, Insert constraint with an offset.
johnsonshiue
Hi! I believe you will need to use Loft command to create the transitional geometry.
Many thanks!
Software Test Engineer
msohaibPLAF8
Thanks for your quick assistance. It's supposed to be one part with a smooth transition.
Specifically, I want to connect the diameter of the smaller tube to the bigger diameter of the other side. I intended to 3d print this adapter to connect air tubes of different diameter.
I have attached a sketch, giving a rough idea of how the transition would like from a side view.
msohaibPLAF8
Thanks for your help.
However, loft command gives a cone like connection. And it would be suitable to have a more curved connection as in the screenshot below.
dave.cutting
You could use the revolve command to utilise the profiles that you sketched.
Dave Cutting
andrewiv
You can still use loft, but you will have to change the condition of your edges.  In the picture I changed Edges1 to a smooth (G2) condition.  You could also use tangent.
Andrew In’t Veld
Designer / CAD Administrator
Logos_Atum
I just had the time to have a quick look. That can easily be achieved using the loft command for sure:
Start with the sideway sketch you supplied. Make sure the height of the connecting sides equal the diameter of the flanges you need to connect. Add two more sketches onto two planes sectioning your sideway sketch. Use the "loft" command and connect the two circles. Then add the curves of your plain side view as sketch rails. You can vary the rails quite a bit. Make sure you´re not selecting a closed sketch, but the two curves that are to join the diameters. If you need more rails, you can add them along on additional planes that you can offset by a few degrees each for example and you´ll get a less "round" result in a way.
 I hope this helps.
Dogs aren´t flammable.
msohaibPLAF8
Thanks!
SBix26
The sections are circular so Revolve is a simple and very robust solution.  Loft faces are not nearly as precise or well-controlled as Revolve faces would be.
Sam B
Inventor Pro 2025 | Windows 11 Home 23H2
