Hi, for a view that has so much detail, I think it would be convenient to use several drawing sheets.
For example, one with the complete deployed model, and others with the details that you want to place.
Apparently the sheet will be cut by laser or some similar system, so the important thing would be to create the correct dxf of the unfolding, if so, many dimensions would be unnecessary, only those of inspection, control of the part I suppose.
The dimensions that describe horizontal (created with ordinate set) can cause confusion because the view is so small.
If they are really necessary, you could add a detail view where the dimensions are superimposed and use a larger scale to make the map more readable. These are just some personal interpretations at a glance, surely the partners can have more important points of view. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
