Bend to surface or plane, or small bends
Hi all,
I'd like help bending this simplified roller gate for a dam. There are conflicting reports of this gate deflecting 3/8" or 1 1/2" when under load, and because of its design it won't behave as a tube or solid cylinder for mathematical problem solving.
Due to its large physical size, a small change in deflection yields a big difference in the size of the gap with its weir, leading to a big difference in the amount of water lost.
I have labeled the important planes to help.
-The roller gate bends while holding water. It bends along Bend direction plane towards Target plane, with maximum deflection at Centerline plane.
-I have tried bending it at Work plane 4 (the "vertical" plane of the main cylinder), Forward bend profile plane and Rear bend profile plane.
It appears that I can't have an arc length longer than the length of the dam, which makes sense. However, it also appears that there are radii that the Bend Part command "simply won't do."
In an ideal world, I'd tell Inventor to bend at the sketched line until the front edge of the gate at Centerline plane touched Target plane, which is currently set 3/8" back from the tip. Still in the ideal world, I'd change the amount of offset of Target plane, which would then rebuild the bend.
Any help would be greatly appreciated, thanks.
Steve
