In de part in the attachment I'm trying to cut away excess sheet metal to produce a rather peculiar shape.
I'm attempting to first create the part curved, then make a flat pattern so the part is able to be cut.
I generated the part first using countour flange, then made an offset plane with the sketch on it.
However once I get to the point of actually cutting it off, it gives the "Bend geometry passes through the bend axis" error. When using the cut command I select the "all" distance with both directions. The error appears to be when generating the flat pattern.
I've tried first creating a normal part, in which this technique works fine. When converting it to sheet metal however it doesn't seem to want to unfold properly and keeps its curved shape.
If anyone could tell me what to change or do it would be much appreciated.
EDIT 1:
Deleting the existing flat pattern did allow me to perform the cut. However now it won't generate a flat pattern. I think I have identified the problem. Because the plane was offset, and the sheet metal curved, it generated a lot of weird edges. I still have not figured out how to either project the 2D sketch onto a 3D shape with all the proper dimensions and/or conversions or how to rebuild the edges so it will fold. Any help in this part would be welcome!
__
Inventor 2018
