Inventor Forum
Basic questions about circular feature pattern
10 REPLIES 10
Message 1 of 11
theycallmevirgo
274 Views, 10 Replies
The attached assembly contains part "neoprene". Feature "Stitch" in "Neoprene" is constructed from a sketch on a plane tangent to the revolved Sketch1. Pattern "Stitches" is a circular pattern along the projected construction line on the offset plane around the constructed axis. Then I mirrored it across the perpendicular plane.
My initial goal was to offset the first "stitch "by a given distance from the "start" of the revolved body and space evenly. I decided on this technique after watching some YT videos. Is it "correct"?
Is there any way to input arc length distance into circular pattern, or will I have to do something clever with Pi/trig/inverse trig?
Thanks so much
Joe
10 REPLIES 10
Message 2 of 11
cidhelp
in reply to: theycallmevirgo
Hello @theycallmevirgo ,
do you want to use the arc-length (on base cylinder) as distance for the holes?
I would sketch an arc for the holepattern and create an arc-length dimension. After creating the first hole, you can pattern (rectangular pattern!) along the arc-path.
Message 3 of 11
SBix26
Several things that would make this simpler for you:
  • Make the X-axis the center of the first Revolution feature so you can use it for subsequent features (not easily corrected in this file due to adaptivity)
  • Instead of creating the Stitch feature as a circular Extrude/Cut, use the Hole feature
  • Holes can be located by a point (location) and axis (direction), so no need to create lots of workplanes
  • Feature patterns have a Midplane button to make the pattern symmetric
I've attached a modified file (2025 format) for you to look at.  Here's the Circular Pattern feature I used showing the Midplane control:
Sam B
Inventor Pro 2025.1 | Windows 11 Home 23H2
Message 4 of 11
theycallmevirgo
in reply to: cidhelp
"do you want to use the arc-length (on base cylinder)
Yes, that's it exactly. I'll try your approach shortly.
Message 5 of 11
theycallmevirgo
in reply to: SBix26
Why do you say using hole reduces the number of workplanes? I'm still using the one offset plane to define the pattern the way I did it originally.
Message 6 of 11
SBix26
Because Hole location and direction can be defined by point and axis, so a sketch is not required.  I used your Sketch2 to define the workpoint and workaxis for the Hole feature, so no further workplanes or sketches required.
Sam B
Message 7 of 11
SBix26
Here's another pattern method which is probably even better for your purposes.  I constrained an arc centered on the projected edge to be the direction for a rectangular pattern, and dimensioned the start point from the edge.  In the pattern, I specified the number of instances and that they be distributed evenly along the curve.  No calculations or arc length dimensions required.
Sam B
Message 8 of 11
theycallmevirgo
in reply to: SBix26
Sorry, but I'm still unclear. Both your technique and my technique use a plane offset from the face created by the revolution, on which we make a sketch from the projected cut surface. What additional planes does my technique use?
Message 9 of 11
theycallmevirgo
in reply to: SBix26
Also - in SBv2 is d24 a linear distance, or an arc length? If a linear distance, do you know how to make it an arc length?
ETA NVM I figured that part out
Thanks again
Joe
Message 10 of 11
theycallmevirgo
in reply to: SBix26
Also, why is the sketch feature line that defines the hole not a construction line? Why does the part break when I make it a construction line?
Thanks again
Joe
Message 11 of 11
theycallmevirgo
in reply to: SBix26
The real problem is, I don't really want to input number of instances for pattern command. I want to do it by arc length spacing and total distance.
