Basic questions about circular feature pattern
theycallmevirgo
theycallmevirgo
The attached assembly contains part "neoprene". Feature "Stitch" in "Neoprene" is constructed from a sketch on a plane tangent to the revolved Sketch1. Pattern "Stitches" is a circular pattern along the projected construction line on the offset plane around the constructed axis. Then I mirrored it across the perpendicular plane.
My initial goal was to offset the first "stitch "by a given distance from the "start" of the revolved body and space evenly. I decided on this technique after watching some YT videos. Is it "correct"?
Is there any way to input arc length distance into circular pattern, or will I have to do something clever with Pi/trig/inverse trig?
Thanks so much
Joe
Replies (10)
cidhelp
Hello @theycallmevirgo ,
do you want to use the arc-length (on base cylinder) as distance for the holes?
I would sketch an arc for the holepattern and create an arc-length dimension. After creating the first hole, you can pattern (rectangular pattern!) along the arc-path.
SBix26
Several things that would make this simpler for you:
  • Make the X-axis the center of the first Revolution feature so you can use it for subsequent features (not easily corrected in this file due to adaptivity)
  • Instead of creating the Stitch feature as a circular Extrude/Cut, use the Hole feature
  • Holes can be located by a point (location) and axis (direction), so no need to create lots of workplanes
  • Feature patterns have a Midplane button to make the pattern symmetric
I've attached a modified file (2025 format) for you to look at.  Here's the Circular Pattern feature I used showing the Midplane control:
Sam B
Inventor Pro 2025.1 | Windows 11 Home 23H2
theycallmevirgo
"do you want to use the arc-length (on base cylinder)
Yes, that's it exactly. I'll try your approach shortly.
theycallmevirgo
Why do you say using hole reduces the number of workplanes? I'm still using the one offset plane to define the pattern the way I did it originally.
SBix26
Because Hole location and direction can be defined by point and axis, so a sketch is not required.  I used your Sketch2 to define the workpoint and workaxis for the Hole feature, so no further workplanes or sketches required.
Sam B
SBix26
Here's another pattern method which is probably even better for your purposes.  I constrained an arc centered on the projected edge to be the direction for a rectangular pattern, and dimensioned the start point from the edge.  In the pattern, I specified the number of instances and that they be distributed evenly along the curve.  No calculations or arc length dimensions required.
Sam B
theycallmevirgo
Sorry, but I'm still unclear. Both your technique and my technique use a plane offset from the face created by the revolution, on which we make a sketch from the projected cut surface. What additional planes does my technique use?
theycallmevirgo
Also - in SBv2 is d24 a linear distance, or an arc length? If a linear distance, do you know how to make it an arc length?
ETA NVM I figured that part out
Thanks again
Joe
theycallmevirgo
Also, why is the sketch feature line that defines the hole not a construction line? Why does the part break when I make it a construction line?
Thanks again
Joe
theycallmevirgo
The real problem is, I don't really want to input number of instances for pattern command. I want to do it by arc length spacing and total distance.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
