Balloon size
Balloon size
lkirit2000
Advisor Advisor
Balloon size
lkirit2000
Hi
Please see attached image below. earlier I inserted some balloons automatically, then I a insert a balloon manually, why that size is not consitant. How to fix it ?
BDCollett
Under the Balloon style there is "SCALE TO TEXT HEIGHT"
You ITEM number likely has a space which is making the balloon scale.
Remove the space and the balloon will return to being small.
lkirit2000
Hi
Appreciate your prompt response and it solved my problem.
I have an other issur that wjem I try sort one component ( item 7) unable to sort either part list and BOM?
PLease see attached image.
What could be the reason.
johnsonshiue
Hi Kiri,
Did you sort by the Item Number? Please share the files in zip here. The forum experts can help take a look.
Many thanks!
Software Test Engineer
lkirit2000
Hi Johnson,
All solved.
johnsonshiue
Hi Kiri,
Please describe how the issue was resolved. It may help other users encountering the same issue.
Many thanks!
