Background Programs
Background Programs
Message 1 of 9
Background Programs
I normally work with 1-1.5 gig assemblies with a lot of components, I also usually have a decent amount of programs open for my work flow. I'm using Inventor 2021, and, this is more of a general question, but in everyone's experience what are some troublesome programs that run in the background in tandem with Inventor?
Replies (8)
Message 2 of 9
johnsonshiue
Hi! I am not aware of such behavior. Do you dedicate certain CPUs for certain processes? Or, you dictate the Affinity?
If possible, please record a video showing the behavior. I would like to understand it better.
In the meantime, please make sure all critical Windows updates are installed, graphics driver is updated, and 2021.3 update is installed.
Many thanks!
Software Test Engineer
Message 3 of 9
Ray_Feiler
Use Task Manager and sort by CPU to find out where your system resources are being used.
Product Design & Manufacturing Collection 2024
Sometimes you just need a good old reboot.
Message 4 of 9
This is mainly pertaining to the fact that, even though there is horsepower available from the computer, there is still considerable lag in Inventor.
Message 5 of 9
I have not done any specific allocations for CPU resources or RAM, is this something that could be customized?
The CPU is an i7-10700 running at 2.9 Ghz, with a turbo of 4.8 Ghz along with 64 GB of DDR4 RAM. Thanks in advance.
Message 6 of 9
johnsonshiue
Hi! A few things to check. It is possible there are still performance related bugs in Inventor, after recent significant improvement in performance. It could be files or workflows specific.
I don't think running programs in the background would cause Inventor to slow. It is because as long as there is enough RAM, other programs should be loaded on system RAM, which should be fast. If swap memory is used, it will be slow. But, it should not be your case.
You mention "turbo" CPU. Do you overclock it? If yes, I suggest you do some testing with it off. Do you see a difference? The reason why "turbo" may not help is that it is forcing CPU to run at a speed it was not designed to do. It may appear it runs faster for certain tasks. But, the turbo may also interfere with multi-threading operations negatively. I suggest you turn the turbo off and see how it works.
The network could play a role here depending on how your files are saved. Do you access files from a shared drive (libraries)? Where are Appearance and Materials libraries stored?
You said that you work on 1.5GB assembly. I assume you are talking about the size of entire files. How much RAM is consumed when it is loaded? Try turning off Express mode (Tools -> App Options -> Assembly -> uncheck "Enable Express Mode"). This option will store assembly graphics at the top-level assembly, which makes the iam file big. It helps speed up file open and see the graphics faster. However, the need to save the such big chunk of graphics data can slow things done somethings (while saving).
Many thanks!
Message 7 of 9
I usually always load full when working with these assemblies, additional the clock speed on the CPU is all stock. The turbo I am referencing is apart of the CPU's architecture.
I've opened a simple assembly to work with and the screencast should illustrate my issue. Any minor movements of the part will cause it to hang repeatedly. CPU usage is fine, as well as RAM utilization.
I've attached the screencast to show the issue, no big assemblies were open and the part that is lagging along with others is merely a tube, and a step model from McMasterCarr. Thanks in advance.
https://knowledge.autodesk.com/community/screencast/d99f9a37-44b8-4ae5-a830-3a0f0008b7a8
Message 8 of 9
johnsonshiue
Hi! The STEP part you downloaded from McMaster site has physical thread, right? If yes, I guess this could be graphics related. The thread does not convey additional design intent besides looking more realistic. Inventor thread is more like a texture to minimize the need to compute the unneeded graphical detail.
Please make sure the dedicated graphics card, instead of the integrated one, runs Inventor.
Many thanks!
Message 9 of 9
gmwi
I have notice that "Windows" doesn't handle streaming and Inventor smoothly a lot of the time. If your streaming videos or music , it BOGS down how well the program runs. I've also notice that screen response frequency makes a snappier cad response. A big TV verses a 75-120 hz screen makes a difference. Just a few things I've noticed in my cad world.
