avast! interfering iLogic rule
This widget could not be displayed.
On my laptop I have installed 'avast! Free antivirus' and in the past this has worked just fine.
However, since the (one of the) latest update of virus definitions the problems started.
When creating a new .idw file an iLogic rule is triggerd to set some properties.
But now avast! thinks this 'automation' is a 'Win32:Evo-gen [Susp]' threat.
Adding the .dll file to the trusted list is nog an option, because the a new .dll file is created each time, with a different name.
I have also tried to add the vbc.exe to the trusted list; also no luck there..
Is there anyone who has the same error, and knows how to solves this?
(Ofcourse I will also post this request at the forums of avast!)
Thanks!
Cadmanto
That is interesting.  I have avast loaded on my PC's as well.  What version of Inventor are you running?
I am wondering if I could load this rule and see if I get the same results as you do.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
I'm running Inventor Pro 2014.
I have attached the template file...
Cadmanto
Sorry, I am still on 2013, so I cannot open your files.
Maybe it would be worthwhile to just disable the avast while you are in Inventor.
Best Regards,
Scott McFadden
rschader
I just ran into this problem today with Inventor 2015, avast updated it's definition file today, and when I was trying to create a new external ilogic rule, my avast popped up saying it blocked a suspicous program, iLogic gave an error messsage it couldn't find some randomly named dll file in my Users/Appdata/Local/Temp directory. Fixed it by excluding that whole directory from scanning, but that's probably not the best thing to do? At least it works for now.
