Automatic Sheet Numbering
RRomer
RRomer
Is there a VBA routine available that will automatically display (update) the sheet number and total number of sheets in a set on each drawing sheet in the set?
i.e.  SHEET "#" OF "#".  If so, how would I incorporate it into the sheet format?
Curtis_Waguespack
Hi RRomer,
This can be done automatically without any VBA. You would edit your title block and use Inventor's built in Sheet Properties > Sheet Number and Drawing Properties > Number of Sheets as shown:
I hope this helps.
Curtis
mdavis22569
Check out
http://forums.autodesk.com/t5/inventor-customization/changing-drawing-sheet-numbers/td-p/5087212
You should be able to do it with Iproperties.. with Drawing properties, where it'll update automatically for you...
how to customize your titleblocks
https://www.google.com/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=custom+title+block+inve...
like this:
Mike Davis
RRomer
Thanks Curtis, I've been told by our CAD Dept. it would take a lot of research and we don't have the resources for that at this time.  I knew it was possible since I had seen it in use at a previous company and SolidWorks has been doing it for years.  Anyway I did some checking on my own and found exactly what you've presented here.  It works well and does exactly what I need.  Now if I can get them to incorporate it into our default formats all will be A LITTLE MORE RIGHT WITH THE WORLD.
Thanks for your quick reply ... problem solved (sort of)
mdavis22569
an update to a titleblock would be about 5 minutes to add this ...
it's already there ...
Mike Davis
