AutoDesk Inventor Professional 2017 Glitching
Can somebody please help me on the following:
I recently downloaded AutoDesk Inventor Professional 2017. I've used the software before on another computer and found it very easy to use. However, when I downloaded it onto my laptop it installed fine and starts fine (can be a little slow at times) but when I click on anything like Part, Assemble or anything within that same sub-window, it brings me to the usual stage where you can start your sketch.
Once I'm at this stage of creating a new part or assembly the screen flickers/glitches every time I drag the mouse across the screen. It's almost as if the screen is constantly refreshing. It's quite infuriating and even when I try and start a sketch and select a plane to sketch in the plane doesn't re-orientate itself so that your looking at it head on - like I thought it should. I've attached a video to show what exactly is happening.
Any help would be much appreciated.
Erik
