Announcements
Autodesk Inventor 2016 Language pack
Hello guys,
I have a little problem at one time i am trying to install autodesk inventor 2016. However the autodesk language pack for this language is already installed. I have tried uninstalling this by:
MsiExec.exe /X{7F4DD591-1964-0001-1033-7107D70F3DB4}
however this did not work.
I also tried fix it however it is not compatiable with windows 10 which i have...
Any help would greatly be appreated,
Asim
mdavis22569
You should be able to use the Microsoft Fix It utility to uninstall the language pack.
http://support.microsoft.com/mats/Program_Install_and_Uninstall
Check out this post:
https://forums.autodesk.com/t5/installation-licensing/inventor-2015-won-t-reinstall-language-pack-is...
Mike Davis
As I have windows 10 Microsoft fix doesn't work
DannyHubbard
Asim,
The string you have there is to uninstall the English Language pack for Inventor 2015, if you are trying to uninstall the English language pack for Invnetor 2016 try the following.
MsiExec.exe /X {7F4DD591-2064-0001-1033-7107D70F3DB4}
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
Your a genius thank you
