Autodesk Assistant LLM Access
gkniksch
gkniksch
I'm curious about options for accessing the LLM that Autodesk Assistant uses. I would like to know if it requires hitting an API end point for a cloud hosted (data center) LLM. Are there options for on-prem or hosting locally on the user's PC?
I work in a very tightly controlled environment from a security standpoint and I would just like to understand the options for minimizing data sharing and cloud computing with this new feature.
johnsonshiue
Hi! There are fairly limited user controls over Autodesk Assistant. I don't believe the level of customization within Autodesk Assistant you are looking for is available at the moment. However, the technology evolves very quickly.
Many thanks!
Software Test Engineer
