Since there is no AutodeskDM website in the Default Web site area...it
sounds like IIS was installed post the ADMS Console. Is there a way to
backup what you have and uninstall ADMS Console and SQL. At that point,
reinstall. During the re-install process you shouldn't see the attached
screen. If you do...make sure you select the IIS option. At that point,
you should be able to connect to it via a remote machine. Another thing
you might want to check prior to doing all this just to be on the safe
side...make sure you have port 80 🙂 If that port is not open, that is
probably going to be the problem. I know you mentioned earlier that you
tried with the firewall off and had the issue but I always want to double
check.
Jim
wrote in message news:5906515@discussion.autodesk.com...
There is no "AutodeskDM Site"
