AutoCad Title Block Template does not appear on added sheets in Inventor
Our company has an AutoCad Title block template that I was able to open and use in Inventor for a drawing. However, when I click to add "New Sheet" to the Inventor drawing, the new sheet layout is blank and does not have the template.
I was able to create the template in Inventor by opening the AutoCAD Title Block .dwg in Inventor and then saving the copy as template. Then to create the Inventor .dwg I clicked new file and selected the new .dwg from the template selections. The block appears on the first sheet but not any additionally created sheets .
How can I get this to be added to additional sheets?
Thanks!
johnsonshiue
Hi! You will need to create a new sheet format. Right-click on the first sheet -> Create Sheet Format -> give it a new name. If you cannot figure it out, please attach an example here. Forum experts should be able to show you steps to make it happen.
Many thanks!
Software Test Engineer
That works!
Thanks!
