AutoCAD Blocks to Inventor Blocks Option Made Permanent
estringer
estringer
We use a lot of AutoCAD blocks as sketch blocks within the IPT environment and I was wondering if there is a way to make the option of AutoCAD Blocks to Inventor Blocks the default behavior rather than having to check the box every time we initiate a new instance of Inventor?
johnsonshiue
Hi! I am sorry I don't think there is a setting to persist on a last used basis.
Many thanks!
Software Test Engineer
estringer
@johnsonshiue ,
Is there a way to change the config file for Inventor that would make it more permanent?
johnsonshiue
Hi! The configuration file is more for export. Unfortunately, I don't think there is a way to configure the import option systematically. I am talking about the manual workflow. For API or automated workflow, certain options can be set for sure.
Many thanks!
