Hi all,
I found below code to create the general notes in drawing idw. It works fine. But, i have one issue with this code. Everytime, i run this code. It simply creates new general notes. I don't want to create the general notes each time. Is it possible to track the general notes and replace the text on each time.
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
' Set a reference to the active sheet.
Dim oActiveSheet As Sheet
oActiveSheet = oDrawDoc.ActiveSheet
' Set a reference to the GeneralNotes object
Dim oGeneralNotes As GeneralNotes
oGeneralNotes = oActiveSheet.DrawingNotes.GeneralNotes
Dim oTG As TransientGeometry
oTG = ThisApplication.TransientGeometry
'Dim dGeneralNote As GeneralNote
'dGeneralNote = oGeneralNotes.delete()
oGeneralNotes.Delete()
' Create text with simple string as input. Since this doesn't use
' any text overrides, it will default to the active text style.
Dim sText As String
sText = iProperties.Value("Custom", "Component type")
Dim oGeneralNote As GeneralNote
oGeneralNote = oGeneralNotes.AddFitted(oTG.CreatePoint2d(3, 3), sText)
Please let me know your ideas.
Thanks for your time and effort in advance.
SJ
You can try to set the Text property of your existing GeneralNote (instead of deleting and re-creating), something like this:
' Set a reference to the GeneralNotes object Dim oGeneralNotes As GeneralNotes oGeneralNotes = oActiveSheet.DrawingNotes.GeneralNotes Dim oGeneralNote As GeneralNote oGeneralNote = oGeneralNotes.Item(1) oGeneralNote.Text = "Your text here"
I assume that you always have only one GeneralNote in your drawing in this example. You may have to loop through the collection of notes if this is not your case.
Hope it helps.
Vladimir
