Inventor Forum
Auto Populate File Name on Export / Print
11 REPLIES 11
Message 1 of 12
amirandaL4VAC
447 Views, 11 Replies
I have to constantly export PDFs, DXFs, and STPs for work. The name field is always blank and I have to fill it in with the file name. Is there anyway to set Inventor so that it always uses the file name when I export / print a file?
Tags (3)
11 REPLIES 11
Message 2 of 12
ampster40
in reply to: amirandaL4VAC
Using File > Export > CAD Format, then changing the file type to .stp for example works in Inventor 2021 and uses the Inventor file name within that field as you are expecting.
How are you completing that process and what version of Inventor are you using?
Message 3 of 12
I'm using Inventor Professional 2022, using the exact same process.
Message 4 of 12
CCarreiras
You can use iLogic rules to export to any type of file (possible by Inventor, of course) and using lot's of configurations, to the exported file, for example by Part Number, File Name, or even combinations with iProperties, parameters etc.
In Autodesk app store you can also find some app to do that, search there:
Here's an example:
https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=3275134152794222964&appLang=en&os=Win64
CCarreiras
Message 5 of 12
Right I know I can use iLogic, but this seems super basic and like it should be the default to name your exported files by the file name. I'm making sure there isn't a much easier way to get this done within Inventor, like an application option?
Message 6 of 12
CCarreiras
Even worst... you have to write the extension!!!!!...
Unfortunately, there's no application option for that...
I used to click in the part file, to get the name, then i change the extension... 😑
CCarreiras
Message 7 of 12
As long as the ipt, iam, idw file is saved, the name show up in export, save as etc.
Message 8 of 12
ampster40
in reply to: Frederick_Law
That might be the key right there.  It has to be saved first as an Inventor file type.
Message 9 of 12
These are parts that have already been saved as Inventor file types. What version are you using?
Message 10 of 12
Did you save the drawing before export?
I'm using 2023 but I believe it's like that since R1.
Unless you have a broken version.
Message 11 of 12
Now that you mention it, I'm able to get the file name when I export as a step, and when I click "export pdf" instead of "print". But still no dice for DXFs.
Message 12 of 12
Ok, if you're saving DXF from face or flat, that won't work.
I usually copy the file name before do that.
You can export idw to PDF.  Instead of Print.
