Attempts to intersect a spline in X-Y with circle in Y-Z fail
Sophi9999
Sophi9999
Hi-
I'm working on a sweep and having trouble intersecting a circle (profile) with the path.
Here's the spline in the X-Y plane.
The problem is that I can't move the profile easily to coordinates that would intersect.
johnsonshiue
Hi Sophi,
You did not attach the file. I can only guess what the issue might be. Inventor is a history-based 3D parametric solid modeler. There is an oreder of creating things. I guess you created the spline on a sketch attached to XY, followed by the circle on a sketch attached to YZ plane. Here is what you need to do.
1) Move End of Part bar to below the spline sketch.
2) Workplane -> pick the spline and pick the endpoint of the spline.
3) Move End of Part bar to the bottom.
4) Right-click on the circle sketch -> Redefine Sketch -> pick the newly created workplane. Now you should be able to reposition the circle.
The other workflow to consider is to create a UCS. Simply drop a UCS in the model space (without picking any geometry). This self-contained coordinate system allows you to create sketch normal to orthogonal planes within the UCS. Also, the UCS can be easily moved or rotated around.
Many thanks!
Software Test Engineer
TheCADWhisperer
Create a new workplane at the endpoint of the spline perpendicular to the end of the spline for your circle sketch.
or
Create a Workpoint at the intersection of the spline and the YZ plane (before the circle sketch) and then Project Geometry in the circle sketch.
or
end all doubt and attach your *.ipt file here and someone will demonstrate using your file.
Sophi9999
I've attached the *.ipt.
Many thanks for the responses, I'll see if I can work with them.
Ideally, I'd just be able to move the center point of the circle to intersect at -0.505, -0.,379 (the point at which it should intersect the spline...
TheCADWhisperer
@Sophi9999 wrote:
... the center point of the circle to intersect at -0.505, -0.,379 (the point at which it should intersect the spline...
Are those X and Y coordinates, as in (X,Y,Z) or (-.505, -.379, ?)
There is no geometry at those coordinates in the file that you attached?
Is this a school assignment?
Are you working from instructions with more information about the design intent?
Sophi9999
Hi-
This is a personal project so no real parameters 🙂
I got the coordinates by hovering over the point I wanted to intersect. I see now that I'm not snapping to the actual coordinates, just getting in the general area. Yes this is in the XY plane. Thanks!
Type a product name
