Hi @CGBenner !
(forgot to login, i'm the OP 😅)
I've made a flowchart that i hope better illustrates the workflow
To better communicate with our ERP system, we need a "process" (e.g. hardening, coating etc.) to be available through the BOM
The solution we have come up with is to:
1) A part that requires additional processes is promoted to an assembly
2) This assembly contains the original part file (geometry) and any additional parts that represents a process
NOTE: these "process parts" are empty .ipt files
3) The "process parts" will be named and stored appropriatly so that they can reused if the same process is needed elsewhere
4) This new assembly file (that is actually still a single part) will now contain BOM information that can be accessed by an ERP system,
5) Each of the "process parts" will have an associated document that explains it, e.g. detailed coating instructions.
6) When creating 2D drawings we would like to capture this document as sheet 2,3,4....... depending on the number of processes
7) the advantage as we see it we can simply update the process document if needed, and the drawings would then automatically catch the latest process doctument
8) Also becasue the process is represented in the BOM we can easily track if the process has been completed by ticking it "as recieved" in our ERP system.
if Inventor have better ways handle processes, please let me know 😄
Regards
Siggi
