Inventor Forum
Attach Symbol to view
6 REPLIES 6
435 Views, 6 Replies
In MDT I used annotation to attach Rev Symbol blocks to view, so if I move
the view the symbol goes with it.
Is there an IV equvilant command to attach sketch symbols to views?
Paul Houlker
Rimex Supply Ltd
www.rimex.com
6 REPLIES 6
You have to main options
The symbols toolbutton will allow you to attach either with a leader or if you choose
without if you highlight a edge before placing the symbol it will be attached to the view.
Or you can select the view (preferably in the browser) and press S for sketch. This
sketch will be attached to the view.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Paul Houlker" <666paulh@rimex.com666> wrote in message
news:B9F7347851744EEEC81B984DE3694F60@in.WebX.maYIadrTaRb...
> Paul Houlker
> Rimex Supply Ltd
> www.rimex.com
Actually I am a little off on that. If you place it without a leader by highlighting a
edge, it will create a leader when you drag it away from the edge. You can rmb on it and
select delete leader though.
Kent
Assistant Moderator
"Kent Keller" wrote in message
news:0973EF62ED4574163C8D2571FCA9B90F@in.WebX.maYIadrTaRb...
view.
Thanks Kent
As an alternative, create a leader-less symbol INSIDE the dotted view
boundary you want to stick to. the association is made automagically.
-Kevin
OK, I got both methods to work, but you have to use the symbols toolbutton.
You cannot just RMB / insert the sketched symbol from the browser.
Thanks guys
Paul Houlker
Rimex Supply Ltd
www.rimex.com
I like that word....Automagically. Thanks Kevin.
Like Supposal...
Dave Jacquemotte
Automation Designer
www.autoconcorp.com
"Kevin Schneider (Autodesk, Inc.)" wrote in
message news:88457F1ECBE217D1031D8306D5059BE3@in.WebX.maYIadrTaRb...
> -Kevin
