Assigned Names for faces Change Color using Ilogic or API
Andrew_Burnett
Andrew_Burnett
I am looking for a way that probably doesn't exist.  I want to change the color of a face in a part file using the assigned name for the face.  Is there any code that will allow you to do this?
MjDeck
You can do this with the NamedEntities iLogic API. Here's a sample (which requires that a few appearance assets already exist in the part).
Dim partDoc As PartDocument = ThisDoc.Document
Dim namedEntities = iLogicVb.Automation.GetNamedEntities(partDoc)
Dim face0 As Face = namedEntities.FindEntity("Face0")
face0.Appearance = partDoc.AppearanceAssets(2)
Mike Deck
Software Developer
Autodesk, Inc.
Andrew_Burnett
Thank you for the quick response.  It worked great.
