Assembly with functional extension springs
Hi!
I am wondering if there is a way to connect functioning extension springs in an assembly.
As part of a semester project we are taksed with drawing the classic architect task lamp in CAD, as you may be aware that involves 4 extention springs. I have been using the "design->spring->extension spring" tool to generate a spring for the purpose, however I can't seem to be able to "joint" og constrain it to fit.
Any help is greatly appreaciated!
JDMather
There are at least three ways, first two are not real-time.
1. Adaptive (modeled within assembly, will update on changes of assembly constraint.
2. Animate Parameter in Inventor Studio (only works in animation).
3. Dynamic Simulation - Spring Joint (works real-time and in simulation, but ends are a bit of a fudge - don't zoom in).
Zip and Attach your assembly here.
Which function will I need to model the adaptive spring within assembly?
JDMather
Your instructor should be covering this topic.
I asked you to Attach your assembly here and you did not do so.
I can only help those who follow my instructions - this is an advanced topic that is difficult to cover if instructions are not explicitly followed.
Which function?
There is not a single "Easy Button" solution.
The solution requires quite a few steps and depends heavily on how "good" of a solution you want/need.
This should have been specified in the assignment instructions.
Sorry about that, I missed the attach part.
We have merely been assigned to make the drawing, how detailed we choose to do it is up to us. I merely wish to make a "niceness" solution to make it as well as I can.
the assembly should be attached here.
I realize there is no "easy" solution for this, however this is an opportuniti for me to learn a bit extra.
