Close
I was browsing another forum and came upon a question that I never really thought about myself as it doesn't posee any issues for me. He is a new user coming from another program and I pointed him towards this forum.
When you section an assembly or part you are left with a display of (usually) half of that part. If you hover over it, you see the prehighlight that shows the entire part, half as active and half as "inactive" or as a "ghost" as he put it.
I say "inactive" in quotes because the software doesn't see this as an inactive part.
His question was whether this "ghost" could be toggled on or off.
Digging through the (Tools>Application Options>Display) and similar places I could not find an option for this. The closest I found was (Tools>Application Options>Color>Disable PreHighlight). This is an easy cut and dry workaround for when you need to present a clean model to a client or coworker, but is there a formal solution for this? I have used other programs that have this setting, but they also handle assembly sections in a different fashion.
Thoughts?
That's not what we are trying to achieve, but I appreciate the response and reference.
No problem.
I have attached 2 images showing a pipe assembly that has been half sectioned.
The first image shows the assembly without hovering over the pipe.
The second image shows the assembly while I am hovering over the pipe.
When hovering over it, the silhouette of the removed (graphically) pipe shows up. (circled in red)
Is there a setting to remove that silhouette?
Hi Wrw,
sorry, you can't do it.
Admaiora
Facebook | Twitter | Youtube
Do you have enable PreHighlight uncheck also.
I have both unchecked and I get no highlight at all unless I click on the part.
I have been working in an assembly, I just tried this in a part file, and it does not seem to work the same.
As mentioned in the original post, I have done this. It does work as a workaround, but this isn't section specific and disables the highlighting of every part all the time. Not only when a section occurs.
For another route of action, is there a way to set up a hotkey/key combonation to toggle those two options? This would be a much more viable solution.
Thank you for the responses.
I have deselected both "enable prehighlight" and "enable enanced highlighting" and am still getting highlight on hover. I only want it to highlight if I select it.
I am trying to constrain two parts and can't see the edges of what I need because the highlight is too dark, not to mention incredibly annoying.
Please tell me how to shut it off. I am working on 2011.
Search the Autodesk Knowledge Network for more content.
New: Get an Activation Code
Mac OS x10.13 Support
Windows 10 Support
Autodesk Online Store Help
Software Downloads
Serial Numbers & Product Keys
Installation & Licensing
Online Activation & Registration
Network License Administration
Sign In / Create Account
Subscription Help
Maintenance Plan Help
Autodesk is a leader in 3D design, engineering and entertainment software.
