Assembly + Design issues
To start, I am fairly new to Inventor but I can generally find an answer to any problem I have online. I haven't been able to this time so here goes.
I have a welding table I am modeling up, because I want to then do stress analysis on a few different designs to see which I would prefer, just for fun mostly.
My issue comes up when I use Design to insert frame members.
In one assembly I did the top part of the frame, then I did an assembly for the legs, bottom bracing, and top bracing separate, so I could pick and choose how I put bracing in, or the amount of legs etc.
I do not want to do a 3D model, because I had difficulty dimension it.
I want to be able to notch the separate legs to the top, as well as the extra bracing I add. When I go to the design tab and click on notch to select the members, no selections come up. I am assuming because they aren't recognized as frame members in an assembly?
How do I edit frame members and get them to interact with other frame members without building the entire thing in one sketch?
I attached a picture circling the area I want to Notch into the frame. I hope I am being clear.
Thank you.
