Assembly constraints
spl1970
spl1970
Please see the attached.
Wonder if anyone can help me with the correct set of constraints that will fix my assembly.
Part 1 is joined to part 2 with a bolt through hole 3.
There will be no movement in the direction of arrow 4 but the pin will be able to move in the direction of arrow 5 but only within the oval slot.
Part 2 will therefore be able to also rotate about 3 and the angle will be free.
Hope that makes sense.
Simon
mcgyvr
Transitional constraint bolt body to slot..
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2016...
spl1970
Great. Thanks for your help.
