Assembly Constraints Issue, Parts are not moving
naderbens
Message 1 of 8
naderbens
Not sure what am I doing wrong here, followed a basic tutorial 101 constraint and looked simple but my application was bit more than what I've watched.
so in this picture I added a rotating ring to the grounded base using constraint and it turns 360Degrees, and want to open and close the 6 fingers by rotating the ring with the help of other parts. every thing is moving until the last connection.
the assembly is attached too.
Replies (7)
Message 2 of 8
JDMather
An assembly file (*.iam) is just a set of instructions on how to assemble the parts.
You must include the parts (*.ipt) files.
Save As>Save as Pack and Go.
Message 3 of 8
CCarreiras
Hi!
Solve your issues first...
CCarreiras
Message 4 of 8
naderbens
hope it works this time
Edit: added parts
Message 5 of 8
naderbens
Thanks for your reply. I did as your suggestion and deleted the issue, but still not moving
Message 6 of 8
CCarreiras
Physically, is impossible to do what you need with the constraints you create.
An example in the image:
In constraint MATE14, you set the faces (white faces in the image) to be connected (parallel), but if the part need to rotate, must exist a certain variable angle between them, as you can see in the image in red.
If you suppress MATE14 it will rotate, but you will need to create other constraints to keep the parts together.
Maybe... showing us the tutorial will help us to find what's wrong with all constraints you are using...
CCarreiras
Message 7 of 8
naderbens
Wow, that is a clear mistake that I didn't count for. that means I'm missing another rotation point.
thank you very much.
the tutorial is here: https://www.youtube.com/watch?v=i0r7q0B2OSA
Message 8 of 8
CCarreiras
Tip:
For these kinds of movements, check the tool JOINTS
But, be advised that due to movement complexity, they are constraints a lot more faulty and complex to work with...
CCarreiras
