Inventor Forum
Inventor Forum
Highlighted
Post 1 of 6
Assembly Constraints doesnt move the part after applying them
2353 Views, 5 Replies
03-21-2013 05:53 AM
Hello!
I am not sure what could have happened to my settings this week, but I noticed when creating assemblies, applying a positional constraint, the parts don't move. In order to get the parts to "move" to their constrained position I have to try and drag them with the mouse then they snap into place. Also updating the assembly works as well.
What setting could I have changed so that once I press apply on a constraint it moves the part immediately?
Sean
AutoDesk Product Design Suite Ultimate 2013
Sean Farr
Product Designer at TESInc.ca
Inventor Professional 2014-Update 2 - AutoCAD Electrical 2014
Win7-x64 | ASUS P8Z77-V | i7 3770 -3.4 GHz | 32GB RAM |
240GB SSD | nVidia GTX 670 4GB - 320.49
Hi SeanFarr,
Sometimes adaptive parts can cause this behavior. If you have adaptive parts in the assembly and toggle the adaptivity off, does that help?
I hope this helps.
Curtis
Post 2 of 6
Re: Assembly Constraints doesnt move the part after applying them
03-21-2013 06:05 AM in reply to: SeanFarr
In your Application Options, Assembly tab - is the box for Defer Update checked or unchecked?
I believe turning that option on causes what you're describing.
John Tyler
Post 3 of 6
03-21-2013 06:28 AM in reply to: jtylerbc
Nope, unchecked!!
Sean Farr
03-21-2013 06:31 AM in reply to: SeanFarr
Hi SeanFarr,
I hope this helps.
Curtis
An Inventor Improvement Idea that needs support:
Post 5 of 6
03-21-2013 06:53 AM in reply to: Curtis_Waguespack
BINGO!
I had 2 adapative parts in this assembly, this is first time I created parts within the assembly using project geomtry. Toggled off their adaptivity and the parts now snap into position after applying constraints.
Thanks Curtis!
Sean
Sean Farr
Post 6 of 6
11-12-2013 08:15 AM in reply to: SeanFarr
I too am having the same problem.  I do not have any adaptive parts. DEFER UPDATE, is not checked.  Along with that after I apply one mate, the part locks into place.
I created a new assembly, two parts, and I couldn't duplicate this.
