ASK THE EXPERTS - Material Use Optimization
andrewdroth
andrewdroth
How do the experts optimize material use when laying out a sheet metal assembly.
Lets use a truncated cone for example. The client has given you a list of the available sheet sizes (lets say 4'x8' and 5'x10') and you need to make up a large cone, the number of horizontal courses are arbitrary.
How do you determine the best use of the materials at hand?
Andrew Roth
rothmech.com
YouTube IconLinkedIn Icon
IV2025 Pro
Apple IIe Workstation
65C02 1.023 MHz, 64 KB RAM
Apple DOS 3.3
Replies (10)
Mark.Lancaster
@andrewdroth
Are you looking for something like Inventor Nesting?  Or are you talking about something different?
Mark Lancaster
andrewdroth
It's like nesting, but in reverse!
Assuming I maintain horizontal welding seams...
I can start with a sheet size that's available, but I need to manually determine how big of a cone section I can cut out of that sheet. And since the cone geometry is static, the cone sections can vary in a lot of ways to make the shape.
I can make the sections taller and have fewer horizontal seams at the expense of having more vertical seams. I can maybe use smaller sheet sizes and get a better material use efficiency, but at the cost of more weld seams.
I can give all these variables costs, but I still need to consider and iterate the different ways to build the cone manually.
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
andrewdroth
See this comment for a visualization.
https://forums.autodesk.com/t5/inventor-forum/sheet-metal-cone-optimize-plate-layout/m-p/8500832/hig...
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
SBix26
Fabrication question: is the fabrication done by welding in the flat, then bending the entire sheet, or by bending sheets, then welding them together?  I expect the latter (forming equipment has some size limitations), but it makes a difference how to approach optimization.
Update: I see from your latest post that you've asked this before and not got a definitive answer.  I don't have anything to offer beyond what you've shown in your previous topic.
Sam B
Inventor Pro 2020.1.1 | Windows 7 SP1
LinkedIn
Cadmanto
If I am reading you correctly, you are talking about the flat pattern laying them out on the sheet sized you specified and utilizing as much of the material as possible with minimal  scrap?
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Best Regards,
Scott McFadden
(Colossians 3:23-25)
andrewdroth
I've worked on both. Welding first in the case of hopper bottoms for grain bins.
But most of the projects it's all formed first due to the thickness involved.
That can add another headache for conical sections. Most of the modern cylindrical rolling machines can get away with little to no 'grip' (the flat bit that is trimmed after the forming) but conical sections it's usually required, and need to be considered.
See this comment.
https://forums.autodesk.com/t5/inventor-forum/sheet-metal-rolling-grip-flat-allowance/td-p/8685849
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
andrewdroth
Yeah, pretty much. Unless the material is cheaper than another weld seam, but for now let's just use the material usage as the metric.
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
lena.talkhina
Hello @andrewdroth  !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
Does anyone have an answer to this? I am trying to see if Inventor is capable of creating flat pattern (cut optimization). I have several small formed aluminum parts that need to be cut from different sizes of sheet metal. Need to create the optimum cut pattern sheet.
swalton
I think this original post was asking if Inventor had a tool to optimize fabrication of large parts.  IE parts bigger than the standard sheet size.  Think tanks in a tank farm, or grain bins.
If your question is the other way: the parts smaller than the standard sheet size then use Inventor Nesting, part of the Product Development and Manufacturing Collection.
Steve Walton
Inventor 2025
Vault Professional 2025
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
