Inventor Forum
This page has been translated for your convenience with an automatic translation service. This is not an official translation and may contain errors and inaccurate translations. Autodesk does not warrant, either expressly or implied, the accuracy, reliability or completeness of the information translated by the machine translation service and will not be liable for damages or losses caused by the trust placed in the translation service. To translate this discussion, select the language.
Inventor Forum
Post 1 of 6
Accepted Solution
arbor press 2014/ rack and pinion design.. inventor 2014
4309 Views, 5 Replies
04-17-2014 02:12 PM
Hi im CAD student nearly finished my  HND.. ive been battling for days trying to get the arbor press tutorial on inventor 2014..
i downloaded the tutorial pack for 2014 but its not in there, im pretty sure its in the 2012 one so i tried to download that & unzip to the tutorial folder for 2014,, this doesnt work..
basically i want this tutorial to reverse engineer the rack and pinion system, im designing an fsae racing car  i have almost everything done exempt my rack and pinion..
i know i could make one pretty qick but it wont function 100 percent,  can anyone help with ethier getting this tutorial or something simmaler with a rack and pinion gear..
ps if anyone has any tips on how to use the gear tools on inventor 2014 for a rack and pinion system as far as i am aware it doesnt allow you 2
thanks alot i only have a few days to finish my project quick replys are appreciated
Here is the assembly (which I downloaded from the 2014 tutorial dataset).
Re: arbor press 2014/ rack and pinion design.. inventor 2014
04-17-2014 02:38 PM in reply to: 0705640
Hi 0705640,
Have a look at this link, I think the arbor press is in the sample files:
http://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/inventor-sa...
I hope this helps.
Curtis
solution.png Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below.
 Inventor Improvement Ideas that need support:
Post 3 of 6
04-17-2014 02:39 PM in reply to: 0705640
Autodesk Inventor 2017 Certified Professional
Post 4 of 6
04-17-2014 03:21 PM in reply to: Curtis_Waguespack
hi thanks for replying.. this is where i have downloaded the 2012 and 2014 sample files its not in there, i managed to get them both working, files like the miki engine and suspension are there but no arbor press
still trying to find it, its maybe in an earlier version of sample files but was sure i read it was 2012.. really been searching for a while, as i said i could model one but i want it to function 100percent.. is there any other tutorials with a rack and pinion involved?
Post 5 of 6
04-17-2014 03:25 PM in reply to: 0705640
The model is in the tutorial files download, NOT the samples files (and it is in the response just above).
Post 6 of 6
04-17-2014 03:37 PM in reply to: JDMather
thanks very much
Post to the Community
New Post
