Inventor Forum
Applying Level of Detail to multiple identical sub-assemblies within main assembly?
6 REPLIES 6
Jacqueline.West
313 Views, 6 Replies
Hi All,
I have a top assembly into which I have inserted 78 identical sub-assemblies (created by component patterns).
The top assembly is now too large and slow. I have gone into the sub-assembly and suppressed the component which is causing the main issue, so the sub-assembly is now at Level of Detail 1. However this doesn't flow through to the main assembly, even if I change it from master to level of detail 1.
I can select each sub-assembly and individually change it's level of detail but this is time consuming. Is there no way I can change the level of detail of all the same sub-assemblies all at once?
Thank you
6 REPLIES 6
CGBenner
in reply to: Jacqueline.West
@Jacqueline.West
Not out of the box, no.  Level of Detail is an option, so Inventor basically wants you to have the control over which LOD (or in the newer releases, Model State) is active at each level.  So,… it’s a double edged sword.
However, there may be some options using iLogic.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use  ACCEPT SOLUTION  to assist other users later.
Also be generous with Likes!  Thank you and enjoy!
Become an Autodesk Fusion Insider
Inventor/Beta Feedback Project
Jacqueline.West
in reply to: CGBenner
Ok Chris, thanks for taking the time to respond.
CGBenner
@Jacqueline.West
I might suggest posting your idea in the iLogic & VB.net forum, and maybe one of the experts in there can help you out.
Chris Benner
andrewiv
You actually can do this but it does require a sequence.  First you select one of your assemblies, RMB and click Select All Occurrences under the Selection fly out.
Then RMB and click on Representation and you can change the LOD for all of the files that are selected.
Andrew In’t Veld
Designer
Jacqueline.West
in reply to: andrewiv
Excellent, thank you for your help Andrew.
mikejones
If you create a level of detail in your main assembly with the exact same name as that in the sub-assemblies then you can use the Link Level Of Detail; now Link Model States, under the productivity dropdown. That will let you pick a level of detail in your main assembly and any sub-assemblies with the same LOD will all be set the same.
Autodesk Certified Professional
