Application for creating a 3D PDF Template
Kay_Rethmeier
Kay_Rethmeier
we would like to edit the existing Autodesk 3D-PDF-templates respectively create our own 3D-PDF-templates.
Questions:
1) Which other applications than Adobe Acrobat Pro can be used to edit/create 3D-PDF-templates?
2) In case of Adobe Acrobat Professional, which is the earliest version, which supports editing 3D-PDF-templates?
Thanks in advance!
Kay
Cheers
Kay (Principal CAD-Consultant)
johnsonshiue
Hi Kay,
Based on my understanding, you don't need to use Acrobat Pro to edit the template. You could use other PDF editor or Adobe Illustrator to do the same. However, I have not done it myself. I cannot confirm the validity.
Many thanks!
Software Test Engineer
