Inventor Forum
Appearance in detail view
5 REPLIES 5
GosponZ
517 Views, 5 Replies
Does anybody know what cause that appearance is mixed. In view is good but in detail is not . See attached picture .
Thank you
5 REPLIES 5
Cadmanto
in reply to: GosponZ
Are your graphics drivers up to date?
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2021
Best Regards,
Scott McFadden
(Colossians 3:23-25)
GosponZ
in reply to: Cadmanto
Yes everything is updated, but this is not problem that is new. It exist for many years.
johnsonshiue
Hi! I believe this is a design view corruption or drawing snapshot corruption issue. Somehow the appearance understood by the drawing is different than the one active in the model. If possible, please share the file with erroneous appearance style.
Many thanks!
Software Test Engineer
GosponZ
in reply to: johnsonshiue
Sorry i can't,
when do solid bodies modeling and apply appearance they show in assembly ok but if change appearance  in solid it will not update in assembly. What is wrong?
johnsonshiue
Hi! Try using Clear Appearance command (the color wheel button with a check mark at the top) to clear appearance. I guess there are multiple appearance overrides at different levels.
Many thanks!
