Good afternoon,
This is similar to this post here, however there are some issues I see that perhaps someone has found a work around for.
I can edit the material appearance by changing the color, or some attribute such as the scene, save and then change it back and save again and subsequently save that back to the styles library and in turn update the thumbnail. And initially I went through half the library and thought I was making excellent progress. When I closed inventor and later reopened it, all my work had vanished and the thumbnails all reverted to the previous state (missing/blank).
I know that some of these appearances are old, but I do not have the complete history. Before going any further I do have some questions. If I delete these appearances and recreate them, will they actually work, or will the result be the same, missing thumbnails?
For appearances that have been identified as in need of replacement and that are in use, would the proper procedure to remake the appearance be as follows?
- Open the open the sheet metal rule used by the appearance "in use".
- Change the Material to something different (doesn't matter which one).
- Save and Close.
- Open the appearance browser and delete the appearance.
- Re-create the appearance.
- Save to the Styles Library.
- Open the sheet metal rule and change the Material to the re-created appearance.
- Save and close.
Is there a way to copy appearances from one library to another (for appearances that are ok) if I were to start from scratch with a new Appearance file (InventorMaterialLibrary.adsklib) that we share via the Vault with our support files? Or is once a library is corrupt, it is time to just start over?
Is there a white paper, or information specific to how materials, styles, etc. are related? Perhaps I just do not understand all the inner workings. Then combine that with pre-inventor 2011 to current release files that are still scattered all over and it just seems a bit confusing. I of course am trying not to infer with anybody else's work as I work to correct these issues or hopefully not introduce new ones. I would really appreciate some input, thank you in advance.
Tom
The attached image shows that the thumbnails in the appearance browser are missing, while the Document appearance is ok. As soon as I add an appearance to the document the thumbnail is correct. I tried changing the thumbnail size in the browser to see if perhaps just a typo in paths behind the scenes. The items underlined with blue are other materials in question. Some I do not see in a clean install, and maybe just need to be deleted- again, these may be left overs from past versions of inventor.
