Appear "0" when i dim chain inventor
tanchau5SG9J
tanchau5SG9J
When i dim chain on this file .idw, it apear "0" at all chain, on the other file .idw i do not see this problem.
Gabriel_Watson
I think your drawing style is aligning the dimensions instead of setting them vertical. Check "Edit Styles" to make sure. See similar thread here:
https://forums.autodesk.com/t5/inventor-forum/0-s-in-chain-dimension/m-p/8468059/highlight/true#M725...
tanchau5SG9J
No, i don't think so. I have solved this problem by i adjust the part file, i have not constrained the line to parallel origin coordinates. After that, i update all model, and create a new section. Ok, i appreciate your support. Thank you very much.
