Ansys Interface
Ansys Interface
I need to import an inventor model into Ansys.
Is it simply done by exporting the inventor model to an Iges/Sat file & importing or is there an Ansys plugin or Addin which is better to use?
I have read some previous posts with ansys users having problems when import inventor model whica have derived/mirror parts etc.
Sandy
harco
There is an addin which gives an automatic link to Ansys.
If you keep the link active you can refresh your Ansys model from changes you make in Inventor.
I don't know about the derived/mirror parts problem so can't really comment.
Binga
Where can I download that addin?
Gilberto Binga
Engenheiro Mecânico - Engenheiro Mecatrônico
deLearning - YouTube Channel
Facebook | LinkedIn
LOUCO POR AUTODESK
A resposta resolve seu problema? Ajude outros usuários marcando "Aceitar como Solução"
Does the answer solve your problem? Help others checking "Accept as Solution"
Curtidas são apreciadas caso tenha gostado da informação
Likes are appreciated if you liked the information.
