Hi All,
I am attempting to use Retrieve Model Annotations to show the diameter of the disc on the section view. It will only show the radius value. I can show it on the front view but that is not preferable.
Thank you for any suggestions.
Garth
Solved by Gabriel_Watson. Go to Solution.
I found the issue. The original sketch was drawn using the XZ plane and I needed to use the YZ plane. My question now is can I change the plane now that the project is complete?
Right click in the browser on the profile sketch and choose 'redefine' then you can choose another plane.
You may have to fix other features after doing this though.
