Animation Rendering Bandwidth
How do I change the bandwidth from 1500kbps to higher, It is not sufficient for my project as there is severe distortion in the animation. As seen below:
SharkDesign
Is this in the studio environment?
Try setting render quality to high and export to AVI.
You might need to render for longer too.
  Inventor Certified Professional
Bill_Bogan1
For what this is worth....
If using Inventor Studio, I select AVI output.
I installed/use the Xvid mpeg-4 codec, choosing it instead of using the Full Frame default. The Xvid dialog (displays during rendering) shows an avg bitrate (kbps) of 10110 for the render I'm doing now and will attach here later. Note: the bitrate changes throughout the rendering activity. I wasn't clear on that point.
To check camera position, I'll use the Preview render option, Quick, low quality.
Test anim render: 15 fps is fine.
Final anim render: 24 or 30 fps.
I've a 9 second anim rendering now and will attempt to post it in this discussion so you can see the results.
-Bill
Bill Bogan
Principal Content Experience Designer
CXD
PDMS-DiD-Digital Manufacturing
Autodesk, Inc.
dav2214159
Community Visitor
Community Visitor
is the "Xvid mpeg-4 codec" a plugin you can download from somewhere?
chris
I highly recommend rendering outside of Inventor, better materials, better lighting, better animation, just throwing that out there
chris
@dav2214159 Here are a couple of examples outside of IV
