Hi
I made a box animation but I don't know why the bottom part of the box is opening instead the upper part moving. I want the upper part to move vertically.
Ted
Solved by TEDPOWERTRAIN. Go to Solution.
1. First thing you should do is right click Ground the base component in your assembly.
See checkmark next to Grounded at bottom of list of options.
2. I do not see an Animate Constraint on your Animation Timeline?
