Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Angular Dimension Help
Im having some trouble showing an appropriate angular dimension in my drawing (see attached). I modeled a bend with a radius of 0.04" at 110 degrees. When I try and retreive these model dimensions in my drawing, I get 64 degrees (or 116 depending on where I place the dimension). I can not manually create the dimension in my drawing because I can not select two components to create the angular dimension. Am I missing something here? Any help would be appreciated.
Create a sketch in that view. Then project edges needed & also create geometry perp.to the angle and dimension from there
Jim C
I don't really understand what you're getting at. Create a new sketch within my part or within the .idw? If within my part, are you saying create a whole new feature and try and dimension off of that?
JDMather
zip and attach the ipt and idw here.
Don't think I'm permitted to. Proprietary/security reasons...
JDMather
Seems like you could create a dummy mock-up file the exhibits the same behavior as your proprietary file.
You could create the sketch in the ipt or idw (in idw click on the red view boundary and hit s on the keyboard). Project Geometry as needed RMB Done. Sketch as needed.
I think I figured it out...After I created the new sketch in my part I had to go back into the model tree within my drawing and click Get Sketch. This projected my new sketch in the drawing and I was able to dimension from there. Then I just made the skecth invisible. Thanks for the help.
