Angling Assembly
Angling Assembly
Angling Assembly
How do I angle the combustion chambers to align with the combustion hull? No surface seems to fit.
Best regards, Isak Lundgren
graemev
First off: an assembly file is just a bunch of hyperlinks to the part files and some info about how they go together. You would need to upload the part files too.
Second: It's helpful to note which release of Inventor you are using, including Service Pack number.
Lastly: Without seeing the actual problem.... You can use the parts' own origin planes and axes for orientation and positioning. You don't have to use part geometry. You may also orient them with respect to the assembly's origin geometry directly. Just be sure that eh part is not also grounded, to avoid conflicts.
TheCADWhisperer
I thought the relation of parts and assemblies were already covered in some detail?
Got it, thanks!
