I am trying to create a pipe extension that can be set to various angles, as seen in the picture. I want to be able to rotate it at point 1 180 degrees, and then at point 2 180 degrees, and anywhere inbetween. So if i rotated point 1 10 degrees, i want to then rotate point 2 20 degrees and have the sketch locked. I want to be able to change those angles as i see fit. The only way i can see doing this is using the parallel constraint on some sort of projected geometry that can incorporate 360 degrees of movement. Any ideas on this? they can be increments of 10 degrees. So ineed some sort of sphere that has lines i can reference at pretty much any 10 degree increment. any help would be greatly appreciated. thank you
